[Qgis-developer] Re: New search, browse and edit UI
Nathan Woodrow madmanwoo at gmail.com
Thu Feb 16 07:19:33 EST 2012
On Thu, Feb 16, 2012 at 5:24 PM, Denis Rouzaud <denis.rouzaud at gmail.com>wrote:
> - If you have a multiple selection, arrows added in the bottom of dialog
> allow you to browse the selection, item per item (replacing Item Browser
> plugin).
> - you can edit the fields as you browse, but you can also apply the
> changes for the whole selection (replacing QuickMultiAttribute plugin -
> great btw)
> - you can search features in the layer using the same edit form. Maybe by
> adding checkboxes in front of each field, you can select which would be
> used in the search. You would browse your result in the same window.
> (replacing qSearch plugin)
-1 Mainly because this might be confusing to what mode you are in and
confuse the user.  I would have to see the UI design first.
- Nathan
URL: http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120216/cf2bc51e/attachment.html
