[Qgis-developer] Postgis provider, add and modify linestring
    Denis Rouzaud
    denis.rouzaud at gmail.com
    Mon Jan 23 08:47:49 EST 2012
Hi all,
I observed a few changes I see as drawbacks.
1. When you draw a line, when you right-click to finish the feature, the
current point is used. I think it is more consistent to place points
with left-clicks and finish with a right, without adding anymore point.
2. Also, when I finish a feature, I have to commit changes and to
refresh the canvas before I can see it on the map. If I am right, it did
not used to be like this.
3. There is no add/remove node for a linestring. I am going to write
this as a plugin. I this planned to be done? Did I look too quickly and
this feature does exist?
Thanks a lot,
Denis
