[Qgis-developer] Postgis provider, add and modify linestring
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jan 23 09:20:44 EST 2012
Hi Denis
 >There is no add/remove node for a linestring
Can't you do that with the node tool?
Regards,
Marco
On 23.01.2012 14:47, Denis Rouzaud wrote:
> Hi all,
> I observed a few changes I see as drawbacks.
> 1. When you draw a line, when you right-click to finish the feature,
> the current point is used. I think it is more consistent to place
> points with left-clicks and finish with a right, without adding
> anymore point.
> 2. Also, when I finish a feature, I have to commit changes and to
> refresh the canvas before I can see it on the map. If I am right, it
> did not used to be like this.
> 3. There is no add/remove node for a linestring. I am going to write
> this as a plugin. I this planned to be done? Did I look too quickly
> and this feature does exist?
> Thanks a lot,
> Denis
> Qgis-developer mailing list
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
