[Qgis-developer] Postgis provider, add and modify linestring
Marco Hugentobler marco.hugentobler at sourcepole.ch
Mon Jan 23 09:31:51 EST 2012
 >Well, as far as I tried, you cannot remove a single node.
 >And to add one, double-click seems to add a node (there is a cross
drawn),  but you cannot move it, and it is added in the wrong segment.
These are probably bugs. The node tool is intended to do exactly these
things.
On 23.01.2012 15:27, Denis Rouzaud wrote:
>> Can't you do that with the node tool?
Dr. Marco Hugentobler
Sourcepole -  Linux&  Open Source Solutions
Churerstrasse 22, CH-8808 Pfäffikon SZ, Switzerland
marco.hugentobler at sourcepole.ch http://www.sourcepole.ch
Technical Advisor QGIS Project Steering Committee
