[Qgis-developer] QGIS Continuos Integration Testing now available
Tim Sutton lists at linfiniti.com
Fri Jul 20 04:04:17 PDT 2012
I have set up a Jenkins job on my server[1] - it will run the tests
with each push to master. In theory it will notify offenders if they
break the tests by email but I havent had a case where I can confirm
that that behaviour works. You can also get an rss feed to the build
service (to get notices for each test run), or if you run android, you
can install a little widget on your phone that will show the current
status.[2] If you are configuring jenkins mood, set the url to [3].
Build results from jenkins are also automatically submitted to the
Dash hosted by OTB[4]
It would be really great to have others setting up Jenkins on
different platforms (mac & windows in particular), I will document the
configuration options I used for the job and put that in git soon.
[1] http://jenkins.linfiniti.com/job/QGIS/
[2] https://play.google.com/store/apps/details?id=hudson.android.mood&hl=en
[3] http://jenkins.linfiniti.com
[4] http://dash.orfeo-toolbox.org/index.php?project=QGIS
Regards
Tim
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
