[Qgis-developer] [Qgis-user] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Etienne Tourigny etourigny.dev at gmail.com
Mon Jul 23 14:19:32 PDT 2012
On Mon, Jul 23, 2012 at 6:14 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
> On Mon, Jul 23, 2012 at 2:50 PM, Etienne Tourigny
> <etourigny.dev at gmail.com> wrote:
>> Sorry, I posted the read-only url without testing, seems it doesn't
>> work - same thing for other plugins like atlas plugin at
>> http://qgis.org/git/atlas.git
>> Can someone please fix this? I have no idea what the read-only git url
>> is supposed to be.
>> The developper git repos is at
>> gitosis at qgis.org:valuetool.git
>> and the repos browser is at
>> http://hub.qgis.org/projects/valuetool/repository
>> In the meantime, I added a zip file at
>> http://hub.qgis.org/attachments/4719/valuetool-0.4.0.zip
> 0.40 seems to work fine [0]. Tested on Mac 10.6.8, latest master
> build, using Kyngchaos.com's matplotlib 1.1.0-2 Python package install
> [1].
that's great
> [0] http://dl.dropbox.com/u/4058089/qgis/valuetool_0.40.png
> [1] http://www.kyngchaos.com/software/python
> The 0.36 update causes a crash when checking the graph choice. The
> subsequent dialog about building stats will not go away (keeps
> returning), eventually leading to a QGIS crash.
that's odd - did this happen just after update, or also in subsequent
qgis runs?  Did not see any of that on linux.
Anybody else have that problem?
Marked 0.3.6 as experimental for the time being.
Etienne
> Larry
>> On Mon, Jul 23, 2012 at 5:37 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>>> On Mon, Jul 23, 2012 at 1:44 PM, Etienne Tourigny
>>>> Folks,
>>>> I have developped matplotlib support for the valuetool plugin, if qwt
>>>> is available it is used as default, but there is an option to use
>>>> matplotlib instead. Could people please test it so I can release it,
>>>> perhaps as experimental?
>>>> It's at the plugin repos http://qgis.org/git/valuetool.git
>>> Etienne, I can't seem to clone from that url:
>>> [larrys]$ git clone http://qgis.org/git/valuetool.git
>>> Cloning into 'valuetool'...
>>> fatal: http://qgis.org/git/valuetool.git/info/refs not found: did you
>>> run git update-server-info on the server?
>>>> I have released a version (0.3.6)  with some other bugfixes in the
>>>> plugins repos today.
>>>> Etienne
>>>> On Mon, Jul 23, 2012 at 10:57 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>>>> Il 23/07/2012 15:56, Werner Macho ha scritto:
>>>>>> IMHO this tool is worth to be integrated as a core plugin. But I know
>>>>>> that means a lot of work porting it to cpp.
>>>>> agreed; it does not need to be ported to C++ to become a core plugin.
>>>>> all the best, and thanks.
>>>>> Paolo Cavallini - Faunalia
>>>>> www.faunalia.eu
>>>>> Full contact details at www.faunalia.eu/pc
>>>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
