[Qgis-developer] [Qgis-user] Fwd: qgis 1.8 on MAC: Problem with qwt and more
Etienne Tourigny etourigny.dev at gmail.com
Tue Jul 24 05:31:25 PDT 2012
Uploaded 0.4.0 as experimental to the main plugin repos.  Those
interested please test and report here or in the valuetool bugtracker.
Also any feedback on the resolved bugs (#4905, #4798, #4796) is
appreciated.
http://hub.qgis.org/projects/valuetool/issues
Etienne
On Mon, Jul 23, 2012 at 6:19 PM, Etienne Tourigny
<etourigny.dev at gmail.com> wrote:
> On Mon, Jul 23, 2012 at 6:14 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>> On Mon, Jul 23, 2012 at 2:50 PM, Etienne Tourigny
>>> Sorry, I posted the read-only url without testing, seems it doesn't
>>> work - same thing for other plugins like atlas plugin at
>>> http://qgis.org/git/atlas.git
>>> Can someone please fix this? I have no idea what the read-only git url
>>> is supposed to be.
>>> The developper git repos is at
>>> gitosis at qgis.org:valuetool.git
>>> and the repos browser is at
>>> http://hub.qgis.org/projects/valuetool/repository
>>> In the meantime, I added a zip file at
>>> http://hub.qgis.org/attachments/4719/valuetool-0.4.0.zip
>> 0.40 seems to work fine [0]. Tested on Mac 10.6.8, latest master
>> build, using Kyngchaos.com's matplotlib 1.1.0-2 Python package install
>> [1].
> that's great
>> [0] http://dl.dropbox.com/u/4058089/qgis/valuetool_0.40.png
>> [1] http://www.kyngchaos.com/software/python
>> The 0.36 update causes a crash when checking the graph choice. The
>> subsequent dialog about building stats will not go away (keeps
>> returning), eventually leading to a QGIS crash.
> that's odd - did this happen just after update, or also in subsequent
> qgis runs?  Did not see any of that on linux.
> Anybody else have that problem?
> Marked 0.3.6 as experimental for the time being.
> Etienne
>> Larry
>>> On Mon, Jul 23, 2012 at 5:37 PM, Larry Shaffer <larrys at dakotacarto.com> wrote:
>>>> On Mon, Jul 23, 2012 at 1:44 PM, Etienne Tourigny
>>>>> Folks,
>>>>> I have developped matplotlib support for the valuetool plugin, if qwt
>>>>> is available it is used as default, but there is an option to use
>>>>> matplotlib instead. Could people please test it so I can release it,
>>>>> perhaps as experimental?
>>>>> It's at the plugin repos http://qgis.org/git/valuetool.git
>>>> Etienne, I can't seem to clone from that url:
>>>> [larrys]$ git clone http://qgis.org/git/valuetool.git
>>>> Cloning into 'valuetool'...
>>>> fatal: http://qgis.org/git/valuetool.git/info/refs not found: did you
>>>> run git update-server-info on the server?
>>>>> I have released a version (0.3.6)  with some other bugfixes in the
>>>>> plugins repos today.
>>>>> Etienne
>>>>> On Mon, Jul 23, 2012 at 10:57 AM, Paolo Cavallini <cavallini at faunalia.it> wrote:
>>>>>> Il 23/07/2012 15:56, Werner Macho ha scritto:
>>>>>>> IMHO this tool is worth to be integrated as a core plugin. But I know
>>>>>>> that means a lot of work porting it to cpp.
>>>>>> agreed; it does not need to be ported to C++ to become a core plugin.
>>>>>> all the best, and thanks.
>>>>>> Paolo Cavallini - Faunalia
>>>>>> www.faunalia.eu
>>>>>> Full contact details at www.faunalia.eu/pc
>>>>>> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
