[Qgis-developer] GUI roadmap for version 2.0
G. Allegri giohappy at gmail.com
Sat Jul 28 07:10:43 PDT 2012
Thanks Larry.
I will try to contribute as soon as I get some free time back after the
next week deadlines!
Do you suggest to use the wiky to share comments?
giovanni
2012/7/27 Tim Sutton <lists at linfiniti.com>
> Hi
> On Fri, Jul 27, 2012 at 1:26 AM, Larry Shaffer <larrys at dakotacarto.com>
> wrote:
> > Hi,
> > I have created a draft roadmap for the GUI for 2.0. At this time it is
> > mostly focused on fixing problems, making components consistent and
> > adherence to HIG for the project [0].
> > http://hub.qgis.org/wiki/quantum-gis/GUI_roadmap_for_version_20
> > If you are interested in helping with this process, or think it should
> > be done differently than I have outlined, please comment here or on
> > the wiki. I am open to any and all input or help.
> > [0]
> http://hub.qgis.org/wiki/quantum-gis/Developers_Manual#HIG-Human-Interface-Guidelines
> Excellent stuff. I think one area we should really focus in on is the
> creation of a library of reusable widgets that address common memes in
> QGIS's user interface. There have already been various discssions to
> this end but the idea still lacks momentum. There are numerouse
> benefits:
> - write once use many is efficient use of programmer time
> - fixing a bug in one place fixes it in all uses of the widget
> - we can write tests against widgets and know that given ui
> functionality is working
> - we can register them as designer widgets to better enable drag 'n
> drop interface design and limit the number of lines of manual UI
> construction code we have
> Regards
> Tim
> > Regards,
> > Larry Shaffer
> > Dakota Cartography
> > Black Hills, South Dakota
> > Qgis-developer mailing list
> > Qgis-developer at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/qgis-developer
> Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
> Please do not email me off-list with technical
> support questions. Using the lists will gain
> more exposure for your issues and the knowledge
> surrounding your issue will be shared with all.
> Visit http://linfiniti.com to find out about:
>  * QGIS programming and support services
>  * Mapserver and PostGIS based hosting plans
>  * FOSS Consulting Services
> Skype: timlinux
> Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120728/e1189088/attachment.html>
