[Qgis-developer] can not start qgis after building qgis
Nathan Woodrow madmanwoo at gmail.com
Mon Jul 30 06:35:48 PDT 2012
You need to run it like this ./qgis if you want to run it from the bin
folder.
- Nathan
Sent from some fancy phone looking thingo
Sent: 30/07/2012 10:38 PM
To: qgis-developer at lists.osgeo.org
Subject: [Qgis-developer] can not start qgis after building qgis
Hi everyone
i am a newer here.
 i run ubuntu 12.04 64bit, and buid after the instruction, but i don't
know  why can not launch qgis. Seem i successfully build $ install it.
below is the linux shell:
-jack at jack:~/apps/bin$ sudo su
root at jack:/home/jack/apps/bin# qgis
The program 'qgis' can be found in the following packages:
 * qgis
 * qgis-plugin-grass
Try: apt-get install <selected package>
root at jack:/home/jack/apps/bin# ls
qbrowser  qgis  qgis_bench
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120730/a030552b/attachment.html>
