[Qgis-developer] can not start qgis after building qgis
Etienne Tourigny etourigny.dev at gmail.com
Mon Jul 30 07:22:17 PDT 2012
Also NEVER run your apps from the root account! Only when you install
them, if you really need to!
Etienne
On Mon, Jul 30, 2012 at 9:38 AM, 李杨 <gisyangli at gmail.com> wrote:
> Hi everyone
> i am a newer here.
>  i run ubuntu 12.04 64bit, and buid after the instruction, but i don't know
> why can not launch qgis. Seem i successfully build $ install it.
> below is the linux shell:
> -jack at jack:~/apps/bin$ sudo su
> root at jack:/home/jack/apps/bin# qgis
> The program 'qgis' can be found in the following packages:
>  * qgis
>  * qgis-plugin-grass
> Try: apt-get install <selected package>
> root at jack:/home/jack/apps/bin# ls
> qbrowser  qgis  qgis_bench
> Qgis-developer mailing list
