[Qgis-developer] R Sextante error
Victor Olaya volayaf at gmail.com
Fri Oct 19 06:12:20 PDT 2012
Thanks!
2012/10/19 rldhont <rldhont at gmail.com>:
> Hi Victor,
> Ticket opens and patch supplies
> http://hub.qgis.org/issues/6545
> René-Luc
> Le 19/10/2012 10:15, Victor Olaya a écrit :
>> That makes sense...
>> Please open a ticket and provide a patch, and I will apply it ASAP
>> Many thanks!
>> Victor
>>> Hi all,
>>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>>> The bug is : The python subprocess doesn't execute the command.
>>> The solution put the parameter shell to False on linux for the subprocess
>>> Popen construction.
>>> Python doc
>>> http://docs.python.org/library/subprocess.html#popen-constructor
>>> On Windows with shell=True, the COMSPEC environment variable specifies
>>> the
>>> default shell. The only time you need to specify shell=True on Windows is
>>> when the command you wish to execute is built into the shell (e.g. dir or
>>> copy). You do not need shell=True to run a batch file or console-based
>>> executable.
>>> If you want I can open an issue and provide a patch.
>>> Regards,
>>> René-Luc
>>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>>> Agustin
>>>> The most useful info here is in the Rlog file that you will find in
>>>> [your-user-folder]/sextante
>>>> That tells us what was the problem with R (if any). Could you please
>>>> send
>>>> it?
>>>> thanks for your help
>>>> Victor
>>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>>> I find  problem at trying to run R scripts within Sextante
>>>>> on ubuntu 10.04 + qgis 1.8
>>>>> I include links to screen captures of the results at attempting to run
>>>>> the provided example script "Create random sample grid":
>>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>>> I've seen a couple or R-Sextante tickets in
>>>>> http://hub.qgis.org/projects/sextante/issues
>>>>> but I think that they are not related to this, as it seems that
>>>>> those users were able to go beyond than I've been. It also seems like R
>>>>> Sextante
>>>>> might be working on windows and not on linux?
>>>>> Should I open a ticket for this in
>>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>>> Thanks
>>>>> Agus
>>>>> QGIS version 1.8.0-Lisboa
>>>>> QGIS code revision exported
>>>>> Compiled against Qt4.6.2
>>>>> Running against Qt4.6.2
>>>>> Compiled against GDAL/OGR1.9.1
>>>>> Running against GDAL/OGR1.9.1
>>>>> GEOS Version3.3.3
>>>>> PostgreSQL Client Version8.4.12
>>>>> SpatiaLite Version2.4.0
>>>>> QWT Version5.2.0
>>>>> _______________________________________________
>>>>> Qgis-developer mailing list
>>>>> Qgis-developer at lists.osgeo.org
>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
