[Qgis-developer] R Sextante error
Agustin Lobo alobolistas at gmail.com
Sat Oct 20 05:17:50 PDT 2012
Great, Ii assume this solves the problem
Victor,
Will we have a new version of the Sextante plugin soon or do we have
to apply the patch ourselves?
Agus
On Fri, Oct 19, 2012 at 3:12 PM, Victor Olaya <volayaf at gmail.com> wrote:
> Thanks!
> 2012/10/19 rldhont <rldhont at gmail.com>:
>> Hi Victor,
>> Ticket opens and patch supplies
>> http://hub.qgis.org/issues/6545
>> René-Luc
>> Le 19/10/2012 10:15, Victor Olaya a écrit :
>>> That makes sense...
>>> Please open a ticket and provide a patch, and I will apply it ASAP
>>> Many thanks!
>>> Victor
>>>> Hi all,
>>>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>>>> The bug is : The python subprocess doesn't execute the command.
>>>> The solution put the parameter shell to False on linux for the subprocess
>>>> Popen construction.
>>>> Python doc
>>>> http://docs.python.org/library/subprocess.html#popen-constructor
>>>> On Windows with shell=True, the COMSPEC environment variable specifies
>>>> the
>>>> default shell. The only time you need to specify shell=True on Windows is
>>>> when the command you wish to execute is built into the shell (e.g. dir or
>>>> copy). You do not need shell=True to run a batch file or console-based
>>>> executable.
>>>> If you want I can open an issue and provide a patch.
>>>> Regards,
>>>> René-Luc
>>>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>>>> Agustin
>>>>> The most useful info here is in the Rlog file that you will find in
>>>>> [your-user-folder]/sextante
>>>>> That tells us what was the problem with R (if any). Could you please
>>>>> send
>>>>> it?
>>>>> thanks for your help
>>>>> Victor
>>>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>>>> I find  problem at trying to run R scripts within Sextante
>>>>>> on ubuntu 10.04 + qgis 1.8
>>>>>> I include links to screen captures of the results at attempting to run
>>>>>> the provided example script "Create random sample grid":
>>>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>>>> I've seen a couple or R-Sextante tickets in
>>>>>> http://hub.qgis.org/projects/sextante/issues
>>>>>> but I think that they are not related to this, as it seems that
>>>>>> those users were able to go beyond than I've been. It also seems like R
>>>>>> Sextante
>>>>>> might be working on windows and not on linux?
>>>>>> Should I open a ticket for this in
>>>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>>>> Thanks
>>>>>> Agus
>>>>>> QGIS version 1.8.0-Lisboa
>>>>>> QGIS code revision exported
>>>>>> Compiled against Qt4.6.2
>>>>>> Running against Qt4.6.2
>>>>>> Compiled against GDAL/OGR1.9.1
>>>>>> Running against GDAL/OGR1.9.1
>>>>>> GEOS Version3.3.3
>>>>>> PostgreSQL Client Version8.4.12
>>>>>> SpatiaLite Version2.4.0
>>>>>> QWT Version5.2.0
>>>>>> _______________________________________________
>>>>>> Qgis-developer mailing list
>>>>>> Qgis-developer at lists.osgeo.org
>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
