[Qgis-developer] R Sextante error
Victor Olaya volayaf at gmail.com
Sat Oct 20 12:14:16 PDT 2012
Agustin
2 quick things:
1) I am going to prepare a document with instructions to use the
latest version from git. That might help you and others as well.
2)If you are doing a presentation about SEXTANTE, that puts you in my
list of "privileged" users :-) That means that you can (and you
should) ask me for direct help or to prepared a tailored version so
you have it ready for your presentation.
Anyway, do you have any deadline for that?. I am presenting SEXTANTE
at the Russian FOSS4G conference in mid november, and I should have a
new version ready by that time. In the meantime, as I said, and if you
do not manage to use git, I can send you just a zip file with changes
that affect the R engine in SEXTANTE, so you can just unzip them in
you QGis plugins folder and test them.
Regards
Victor
2012/10/20 Agustin Lobo <alobolistas at gmail.com>:
> i understand the hassle, but from the point of view of R scripts in
> Sextante this is not a bug, it is
> that Sextante is totally unusable for this purpose. My intention was
> to include this Sextante capability
> within my (hopefully) forthcoming presentation on geospatial
> capabilities of R in a R users meeting, (and have
> been trying using it, see
> http://osgeo-org.1560.n6.nabble.com/R-scripts-for-raster-layers-in-External-Apps-of-the-Sextante-Toolbox-plugin-td4998046.html).
> I will try the git thing (now that Ii know hot to use svn...), if I
> find directions on how to do it.
> Agus
> On Sat, Oct 20, 2012 at 4:53 PM, Victor Olaya <volayaf at gmail.com> wrote:
>> Agustin,
>> There are a few importante changes since last version, but I would
>> like to close a couple of bugs before releasing a new version. The
>> patch, I will apply it today and it will be in the github repo.
>> In short, I guess you can count on a new version in less than a month
>> (there is not a well defined roadmap at the moment, but that is a good
>> estimate). If you want to always have the most recent version (with
>> unstable stuff as well...), using the github version is the
>> recommended way of doing it.
>>> Great, Ii assume this solves the problem
>>> Victor,
>>> Will we have a new version of the Sextante plugin soon or do we have
>>> to apply the patch ourselves?
>>> Agus
>>> On Fri, Oct 19, 2012 at 3:12 PM, Victor Olaya <volayaf at gmail.com> wrote:
>>>> Thanks!
>>>> 2012/10/19 rldhont <rldhont at gmail.com>:
>>>>> Hi Victor,
>>>>> Ticket opens and patch supplies
>>>>> http://hub.qgis.org/issues/6545
>>>>> René-Luc
>>>>> Le 19/10/2012 10:15, Victor Olaya a écrit :
>>>>>> That makes sense...
>>>>>> Please open a ticket and provide a patch, and I will apply it ASAP
>>>>>> Many thanks!
>>>>>> Victor
>>>>>>> Hi all,
>>>>>>> With a friend of mine, we identifying a bug on Ubuntu with R in sextante.
>>>>>>> The bug is : The python subprocess doesn't execute the command.
>>>>>>> The solution put the parameter shell to False on linux for the subprocess
>>>>>>> Popen construction.
>>>>>>> Python doc
>>>>>>> http://docs.python.org/library/subprocess.html#popen-constructor
>>>>>>> On Windows with shell=True, the COMSPEC environment variable specifies
>>>>>>> the
>>>>>>> default shell. The only time you need to specify shell=True on Windows is
>>>>>>> when the command you wish to execute is built into the shell (e.g. dir or
>>>>>>> copy). You do not need shell=True to run a batch file or console-based
>>>>>>> executable.
>>>>>>> If you want I can open an issue and provide a patch.
>>>>>>> Regards,
>>>>>>> René-Luc
>>>>>>> Le 19/10/2012 10:01, Victor Olaya a écrit :
>>>>>>>> Agustin
>>>>>>>> The most useful info here is in the Rlog file that you will find in
>>>>>>>> [your-user-folder]/sextante
>>>>>>>> That tells us what was the problem with R (if any). Could you please
>>>>>>>> send
>>>>>>>> it?
>>>>>>>> thanks for your help
>>>>>>>> Victor
>>>>>>>> 2012/10/19 Agustin Lobo <alobolistas at gmail.com>:
>>>>>>>>> I find  problem at trying to run R scripts within Sextante
>>>>>>>>> on ubuntu 10.04 + qgis 1.8
>>>>>>>>> I include links to screen captures of the results at attempting to run
>>>>>>>>> the provided example script "Create random sample grid":
>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante1.jpeg
>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante2.jpeg
>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante3.jpeg
>>>>>>>>> http://dl.dropbox.com/u/3180464/Rsextante4.jpeg
>>>>>>>>> I've seen a couple or R-Sextante tickets in
>>>>>>>>> http://hub.qgis.org/projects/sextante/issues
>>>>>>>>> but I think that they are not related to this, as it seems that
>>>>>>>>> those users were able to go beyond than I've been. It also seems like R
>>>>>>>>> Sextante
>>>>>>>>> might be working on windows and not on linux?
>>>>>>>>> Should I open a ticket for this in
>>>>>>>>> http://hub.qgis.org/projects/sextante/issues ?
>>>>>>>>> Thanks
>>>>>>>>> Agus
>>>>>>>>> QGIS version 1.8.0-Lisboa
>>>>>>>>> QGIS code revision exported
>>>>>>>>> Compiled against Qt4.6.2
>>>>>>>>> Running against Qt4.6.2
>>>>>>>>> Compiled against GDAL/OGR1.9.1
>>>>>>>>> Running against GDAL/OGR1.9.1
>>>>>>>>> GEOS Version3.3.3
>>>>>>>>> PostgreSQL Client Version8.4.12
>>>>>>>>> SpatiaLite Version2.4.0
>>>>>>>>> QWT Version5.2.0
>>>>>>>>> _______________________________________________
>>>>>>>>> Qgis-developer mailing list
>>>>>>>>> Qgis-developer at lists.osgeo.org
>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
