[Qgis-developer] Size of bar?
leyan ouyang ouyang.leyan at hotmail.com
Fri Sep 21 00:08:19 PDT 2012
It allows you to change the length of the scale bar, but it is strangely limited to two digits and will get reset if the value is not judged in the good range.
Try to input a value like 40 and zoom until 40m would be considered an acceptable value. There will be a few level of zoom where the bar is set to 40m. Once you zoom in or zoom out too far, it will get calculated as usual.
I agree that this behavior is not very good nor intuitive ...
Regards,
Leyan
> Date: Fri, 21 Sep 2012 07:45:27 +0200
> From: cavallini at faunalia.it
> To: qgis-developer at lists.osgeo.org
> Subject: [Qgis-developer] Size of bar?
> Hi all.
> What is the use of the View>Decorations>Scale bar>Size of bar? I tried changing it,
> but I do not see an effect.
> All the best.
> Paolo Cavallini - Faunalia
> www.faunalia.eu
> Full contact details at www.faunalia.eu/pc
> Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20120921/d42f5669/attachment.html>
