[Qgis-developer] Size of bar?
Paolo Cavallini cavallini at faunalia.it
Fri Sep 21 10:12:35 PDT 2012
Il 21/09/2012 09:08, leyan ouyang ha scritto:
> It allows you to change the length of the scale bar, but it is strangely limited to
> two digits and will get reset if the value is not judged in the good range.
> Try to input a value like 40 and zoom until 40m would be considered an acceptable
> value. There will be a few level of zoom where the bar is set to 40m. Once you zoom
> in or zoom out too far, it will get calculated as usual.
Thanks a lot Leyan.
Paolo Cavallini - Faunalia
www.faunalia.eu
Full contact details at www.faunalia.eu/pc
Nuovi corsi QGIS e PostGIS: http://www.faunalia.it/calendario
