[Qgis-developer] WFS Selection UI Improvements
Tim Sutton
lists at linfiniti.com
Tue Apr 2 02:19:28 PDT 2013
Hi
On Tue, Apr 2, 2013 at 5:23 AM, Jeremy Palmer <JPalmer at linz.govt.nz> wrote:
> Hi QGIS devs,
> Do you think it is possible to get this UI improvement merged before 2.0?
> https://github.com/qgis/Quantum-GIS/pull/494
> Sorry if this type of change was required before the feature freeze, but I've been a little busy over the last few weeks. However I guess it is debatable if this is a feature or a UI change.
Ok I have merged it - thanks!
> One other change that I would like to see in QGIS 2.0 is the ability for the WFS provider to implement the subsetString() method. This would allow users can change the layer attribute filter once the layer has been added map. I'm close to finishing testing on this, but it will take one or two more days to complete. Would it be possible to get this accepted post the feature freeze as well?
I think its ok - double enthusiasm on my side if it comes with a unit test :-)
Regards
Tim
Regards
Tim
> Thanks,
> Jeremy
> This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
> Qgis-developer mailing list
Tim Sutton - QGIS Project Steering Committee Member (Release Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
* QGIS programming and support services
* Mapserver and PostGIS based hosting plans
* FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
