[Qgis-developer] Updating core plugins
Borys Jurgiel lists at borysjurgiel.pl
Sun Apr 21 15:02:47 PDT 2013
Dnia niedziela, 21 kwietnia 2013 o 23:24:49 Victor Olaya napisał(a):
> Hi all
> Having SEXTANTE as a core plugin in QGIS is really great, but I am
> worried about how that will affect users when 2.0 is released. My two
> main concerns are:
> - People currently using SEXTANTE as a non-core plugin will have 2
> versions of SEXTANTE installed when they install 2.0. This is likely
> to cause strange behaviour, and, as some users have reported on the
> mailing list, it seems that the non-core plugin (in this case, the
> older version), will override the other one. Not a nice thing... The
> solution is to manually uninstall it, but that is going to cause a lot
> of confusion...
Yes, non-core plugin overrides the core one (just because of the Python path
order), so the only thing you can do is to make the core SEXTANTE version
higher - at least QGIS will warn about the override and suggest manual
uninstall.
But we use the new .qgis2 directory, so I guess we just should tell users to
not copy the .qgis to .qgis2 thoughtlessly...
In addition, we could prevent QGIS 2.0 from loading uncompatible plugins. The
repository and the installer assume, that plugins with qgisMinimumVersion==1.x
are only compatible with 1.x unless it's strictly set by an optional tag
qgisMaximumVersion (>= 2.0). The same behaviour could be implemented for
loading plugins.
> - I have a few features that will not be ready for 2.0, but I would
> like to release them later, just releasing a new versino of SEXTATE
> independently. However, I think that core plugins cannot be updated.
> Installing the new one separately will cause two version to be
> installed...
Exactly, the base version in core and updates in user directory. The problem
will be when you release a new version with QGIS 2.1, the updates for 2.0 will
override the new version. But we can improve the override detection procedure
for 2.1 (for example, the installer could uninstall the overriding version
instead of only warning)
> Any ideas on that? I see that the easiest solution would be to have
> something in the plugin manager that, in case of having two versions
> of a plugin, would use just the most recent one.
Or uninstall the overriding plugin, if older. It would be probably more
elegant solution...
> Thanks in advance!
> Victor
> Qgis-developer mailing list
