[Qgis-developer] qgis-webclient - weblinks from features and base layers
Otto Dassau dassau at gbd-consult.de
Tue Apr 23 05:34:42 PDT 2013
Hi Bernhard,
yes, that doesn't work properly.
<a class="popupLink" href="http://www.qgis.org">QGIS Homepage</a>
ends up in a string ("QGIS Homepage' target="_blank">QGIS Homepage), where
the second link (QGIS Homepage) works and the first one is wrong. So that
doesn't work well.
But <a href=http://www.qgis.org>QGIS Homepage</a> is fine.
Regards
Otto
Am Tue, 23 Apr 2013 13:37:00 +0200
schrieb Bernhard Ströbl <bernhard.stroebl at jena.de>:
> Hi Otto,
> you are right. This won't work. The automatic url detection is for
> simpler cases where users store a pure url in a field. This url is
> detected and displayed as a link without any html writing necessary.
> So if you want to individually format a complete link with html tags you
> may do it as you showed. If you do
> <a class="popupLink" .... the link gets styled as defined in popup.css.
> I cannot test currently but I think that you might get another <a> tag
> around your link. Is that true?
> Bernhard
> Am 23.04.2013 12:47, schrieb Otto Dassau:
> > Hi Bernhard,
> > thanks for the hint, but how would that work in pratice, if I don't want
> > to show the complete link but a description?
> > At the moment to display "QGIS Homepage" I use:
> > Regards
> > Otto
> > Am Tue, 23 Apr 2013 12:26:27 +0200
> > schrieb Bernhard Ströbl<bernhard.stroebl at jena.de>:
> >> Hi Otto,
> >> actually this works but is a bit outdated. If you are using the latest
> >> webclient with the popups you should be able to simply store an URL in a
> >> field and qwc automgically detects it and forms the<a>-tag around it so
> >> it becomes a clickable link.
> >> Bernhard
> >> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
> >>> Hi Otto
> >>> you can see the replay of Bernard Stroebl about this:
> >>> http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
> >>> Regards
> >>> Leonardo
> >>> On Tue, 23 Apr 2013 09:25:23 +0200, Otto Dassau<dassau at gbd-consult.de>
> >>> wrote:
> >>>> Hi,
> >>>> is it possible to have clickable web links from features in the qgis
> >>>> webclient? And if yes, would I need qgis master to use it?
> >>>> And another question. I saw that e.g. qgiscloud allows to choose base
> >>>> layers
> >>>> from google, bing, ... with qgis webclient. This does not seem to be
> >>> part
> >>>> of the "official" repository in github - right? Is it planned to
> >>> integrate
> >>>> this functionality or is somebody already working on it?
> >>>> I found several mailings but not really a solution or clear hint.
> >>>> Regards
> >>>> Otto
> > __________ Information from ESET Mail Security, version of virus
> > signature database 8256 (20130423) __________
> > The message was checked by ESET Mail Security.
> > http://www.eset.com
> __________ Information from ESET Mail Security, version of virus signature
> http://www.eset.com
Geoinformatik Büro Dassau - http://www.gbd-consult.de
FOSSGIS consulting , training , support  and analysis
Ackerstrasse 144c  ,  D - 40233 Düsseldorf  , Germany
Tel: +49-(0)211-47468178 , Mobil: +49-(0)171-4687540
Community Advisor - QGIS Project Steering Committee
