[Qgis-developer] qgis-webclient - weblinks from features and base layers
Bernhard Ströbl bernhard.stroebl at jena.de
Tue Apr 23 06:50:45 PDT 2013
Otto,
I made a pull request fixing this issue. If a url is detected
(http://something) in an attribute it is checked whether there is an
opening "<a" - tag and only if this is false the tag is automagically
created. So if you store a complete html-formatted link in your
attribute it should be displayed as stored.
Bernhard
Am 23.04.2013 14:34, schrieb Otto Dassau:
> Hi Bernhard,
> yes, that doesn't work properly.
> <a class="popupLink" href="http://www.qgis.org">QGIS Homepage</a>
> ends up in a string ("QGIS Homepage' target="_blank">QGIS Homepage), where
> the second link (QGIS Homepage) works and the first one is wrong. So that
> doesn't work well.
> But<a href=http://www.qgis.org>QGIS Homepage</a>  is fine.
> Regards
> Otto
> Am Tue, 23 Apr 2013 13:37:00 +0200
> schrieb Bernhard Ströbl<bernhard.stroebl at jena.de>:
>> Hi Otto,
>> you are right. This won't work. The automatic url detection is for
>> simpler cases where users store a pure url in a field. This url is
>> detected and displayed as a link without any html writing necessary.
>> So if you want to individually format a complete link with html tags you
>> may do it as you showed. If you do
>> <a class="popupLink" .... the link gets styled as defined in popup.css.
>> I cannot test currently but I think that you might get another<a>  tag
>> around your link. Is that true?
>> Bernhard
>> Am 23.04.2013 12:47, schrieb Otto Dassau:
>>> Hi Bernhard,
>>> thanks for the hint, but how would that work in pratice, if I don't want
>>> to show the complete link but a description?
>>> At the moment to display "QGIS Homepage" I use:
>>> Regards
>>> Otto
>>> Am Tue, 23 Apr 2013 12:26:27 +0200
>>>> Hi Otto,
>>>> actually this works but is a bit outdated. If you are using the latest
>>>> webclient with the popups you should be able to simply store an URL in a
>>>> field and qwc automgically detects it and forms the<a>-tag around it so
>>>> it becomes a clickable link.
>>>> Bernhard
>>>> Am 23.04.2013 09:43, schrieb lami at gis3w.it:
>>>>> Hi Otto
>>>>> you can see the replay of Bernard Stroebl about this:
>>>>> http://lists.osgeo.org/pipermail/qgis-user/2012-October/019798.html
>>>>> Regards
>>>>> Leonardo
>>>>> On Tue, 23 Apr 2013 09:25:23 +0200, Otto Dassau<dassau at gbd-consult.de>
>>>>> wrote:
>>>>>> Hi,
>>>>>> is it possible to have clickable web links from features in the qgis
>>>>>> webclient? And if yes, would I need qgis master to use it?
>>>>>> And another question. I saw that e.g. qgiscloud allows to choose base
>>>>>> layers
>>>>>> from google, bing, ... with qgis webclient. This does not seem to be
>>>>> part
>>>>>> of the "official" repository in github - right? Is it planned to
>>>>> integrate
>>>>>> this functionality or is somebody already working on it?
>>>>>> I found several mailings but not really a solution or clear hint.
>>>>>> Regards
>>>>>> Otto
>>> __________ Information from ESET Mail Security, version of virus
>>> signature database 8256 (20130423) __________
>>> The message was checked by ESET Mail Security.
>>> http://www.eset.com
>> __________ Information from ESET Mail Security, version of virus signature
>> http://www.eset.com
__________ Information from ESET Mail Security, version of virus signature database 8257 (20130423) __________
http://www.eset.com
