[Qgis-developer] QGIS hanging when opening a FileGDB on 64 bit Linux
Jeremy Palmer JPalmer at linz.govt.nz
Sat Aug 10 14:08:00 PDT 2013
Hi QGIS devs!
Since the latest round of code changes (maybe over the last 2 months) I can no longer open Esri FileGDB in QGIS. I can read the database and QGIS prompts me from the FileGDB layers to add to the map, but when I select the layer from this dialog QGIS just hangs. I did some debugging and it seems to hang on the OGR_DS_Destroy call within QgsOgrFeatureIterator::close(). Does anyone else have this problem?
I'm running FileGDB SDK 1.3 and Ubuntu 12.04 64bit with QGIS master. I've tested this with the OSGeo4W win32 qgis-dev package and I don't get the problem.
Could this be related to this issue: http://forums.arcgis.com/threads/76527-CloseDatabase-hanging-on-64-bit-Linux-when-same-File-Geodatabase-opened-twice
Cheers,
Jeremy
This message contains information, which is confidential and may be subject to legal privilege. If you are not the intended recipient, you must not peruse, use, disseminate, distribute or copy this message. If you have received this message in error, please notify us immediately (Phone 0800 665 463 or info at linz.govt.nz) and destroy the original message. LINZ accepts no responsibility for changes to this email, or for any attachments, after its transmission from LINZ. Thank You.
