[Qgis-developer] Renaming SEXTANTE
Tim Sutton lists at linfiniti.com
Sun Aug 11 16:01:52 PDT 2013
Hi
On Sat, Aug 10, 2013 at 3:06 AM, Larry Shaffer <larrys at dakotacarto.com>wrote:
> Hi Victor,
> On Fri, Aug 9, 2013 at 11:53 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> Hi
>> After much thinking and considering some suggestions, I think it would
>> be a good idea to remove the SEXTANTE branding, and just have
>> everything with a more descriptive name, such as "geoanalysis",
>> "processing", or something like that. In the long-term, that will help
>> to integrate the analysis framework into QGIS,and help users locate
>> it.
>> It shouldn't be more difficult than just replacing string ocurrences,
>> but before doing such a big (and potentially troublesome) change, I
>> would like to hear the opinion you guys have about this (is it a good
>> idea? what name should we use instead of "sextante" for packages and
>> modules? any good refactoring tool that you recommend?,etc)
>> I am going to be out of office next week, so I might not read my email
>> everyday, but it would be great to hear what you think about it. Once
>> I am back, I will proceed to change it,
>> I discussed it briefly with Tim and Paolo, who agreed on this, so I
>> assumme this is not incompatible with the API freeze and the release
>> plan that we have, but if anyone thinks this shouldn't be done now,
>> please say it. I personally think that it would be good to have it in
>> 2.0, so all analysis stuff is called "analysis" (or whatever) and not
>> with a name that (although I like and feel very identified with it)
>> for most people doesn't make much sense...
> Agreed (to the doesn't make much sense to users). +1 from me for this much
> needed approach to the naming of core plugins.
> Concerning branding (and with no disrespect to any third-party projects
> brought into core), the brand is not SEXTANTE, not fTools, not GDALTools...
> the brand is QGIS.
> Here are some examples of current branding confusion for a user:
> * GDALTools, fTools, and SEXTANTE are listed in the Plugin Manager. These
> names are indecipherable to a new user, especially one new to GIS or FOSS4G.
> * Once activated, there is no indication that any particular part or
> action of the Vector menu is related to fTools, so it's hard for a user to
> discern core functionality from a plugin's. This is the way core plugins
> should be shown, as part of the app. In this case, however, there is a
> disconnect due to branding.
> * The Raster menu has GDALTools settings at the bottom of it. Again, it is
> unclear to which tools these settings apply.
> * In the SEXTANTE Toolbox there is a big button at the top, which links to
> a third-party site. While this makes sense for a third-party plugin, it is
> inconsistent with other core tools, and makes it appear the tool is not
> actually a core functionality. A discrete Help button at the bottom of the
> toolbox, that goes to QGIS-related help for the tool makes more sense.
> In my opinion, the following core plugins should be renamed to similar
> names as such:
> SEXTANTE -> Geoanalysis Tools
> GDALTools -> Raster Tools
> fTools -> Vector Tools
> Their icons should be updated to reflect their place and purpose within
> QGIS.
> An example of a core plugin that looks and acts like a core plugin to QGIS
> is DB Manager. There is absolutely no disconnect between name, due to
> unnecessary branding, or purpose in the app, to the user. The user clearly
> understands what it is in Plugin Manager and, once activated, the plugin
> blends in nicely as part of the app (though maybe the icon needs updated to
> match newer ones).
> This is not to say credit should be ignored. These are considerable
> contributions to the project. The underlying external projects ported to
> core should reasonably be accessible to the user, possibly in the About
> dialog, and possibly with links directly to an external resource for each
> (where appropriate). This should probably be done for providers as well.
> Side note: there should probably also be some indication within Plugin
> Manager that a plugin is 'core,' hopefully prompting a user that it is
> something they should not generally consider disabling.
> Regards,
> Larry
100% agreed with your points Larry.
regards
Tim
>> Thanks in advance.
>> Victor
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Irc: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130812/f3c467aa/attachment-0001.html>
