[Qgis-developer] [qgis webclient] hide layer in menu
    Giovanni Manghi
    giovanni.manghi at faunalia.pt
    Thu Aug 29 06:50:35 PDT 2013
Hi Andreas,
there is a way to have a layer always visible but do not have it in the TOC?
cheers!
>  Hi Otto,
>  If you provide the "visibleLayers" property in the URL, it will be
>  used. If you do not provide this property it will use the visibility
>  setting from the QGIS?project. You need to set
>  var useGetProjectSettings = true;
>  to be able to use the visibility from the QGIS?project. It does not
>  work with GetCapabilities.
