[Qgis-developer] Several errors
Sanghee Shin endofcap at gmail.com
Tue Feb 12 06:49:32 PST 2013
Dear Andre,
2013. 2. 12., 오후 3:52, Andre Joost <andre+joost at nurfuerspam.de> 작성:
> Am 12.02.2013 06:44, schrieb Sanghee Shin:
>> 3. QGIS Master version stil doesn't reflect the current EPSG info,
>> that is very essential to Korean QGIS users. So, Korean users had to
>> update the qgis.db&  srs.db manually during the training. Actually I
>> raised this issue and opened a ticket around 2 month ago.
>> http://hub.qgis.org/issues/6820 However nothing updated so far. As
>> far as I know crssync should sync with GDAL automatically during
>> installation, however it seems not to work. Is it a bug of crssync?
> In your bug report, you should specify which EPSG-code you want to use, and why the EPSG-codes available are not useful for you. We have over 55000 EPSG-codes, and most of the developers have never worked with Korean data. So they need a bit assistance from your side.
Basically I don't think it's the problem of Korean SRS but I believe it's the problem of crssync. Anyway I would like to answer to your inquires.
1. Current srs.db missed EPSG code from 5167 through to 5188. This means current srs.db missed at least 22 newly updated EPSG codes from EPSG ver 7.9 or ver 8.0. When I run 'epsg_tr.py 5167 5188', I can clearly get the full CRS information from GDAL. However I couldn't see those CRSs from QGIS. Would you please test it out whether your QGIS contains EPSG code from 5167 to 5188?
2. Actually we already got many issues regarding this SRS info from inside & outside of Korea. And we distributed patched srs.db & qgis.db through our web page for the people in need.
> Normally, crssnc should synchronize QGIS database with GDAL's csv-data. If the setup breaks at some stage, this synchronisation will fail. For QGIS Lisboa Windos standalone, this happens when there are blanks in installation folder names. Maybe Korean user names have the same effects.
I tested it with QGIS 1.9.0 Alpha master nightly build version on my Windows, Mac OSX and Ubuntu. And got the same result. And there is no blanks in installation folder name. For example on windows, c:\osgeo4w\... is my default folder name.  So I believe that this can be a bug of crssync.
I tried to find postinstall.log but I couldn't. However I found setup.log showing this kind of error.
2013/02/12 13:42:30 running: cmd.exe /c C:\OSGeo4W\etc\postinstall\sip.bat
2013/02/12 13:42:30 running: cmd.exe /c C:\OSGeo4W\etc\postinstall\qgis-dev.bat
2013/02/12 13:42:32 abnormal exit: exit code=-1073741511
2013/02/12 13:43:52 note: Installation Complete
Any idea on this?
> Look out for postinstall.log for error messages. If successfull, you will find:
>> Synchronizing CRS database with PROJ definitions.
>> xyz CRSs updated.
> HTH,
> André Joost
> Qgis-developer mailing list
Your help will be appreciated.
sanghee
