[Qgis-developer] Several errors
Andre Joost andre+joost at nurfuerspam.de
Tue Feb 12 09:27:03 PST 2013
Am 12.02.2013 15:49, schrieb Sanghee Shin:
> Basically I don't think it's the problem of Korean SRS but I believe
> it's the problem of crssync. Anyway I would like to answer to your
> inquires.
> 1. Current srs.db missed EPSG code from 5167 through to 5188. This
> means current srs.db missed at least 22 newly updated EPSG codes from
> EPSG ver 7.9 or ver 8.0. When I run 'epsg_tr.py 5167 5188', I can
> clearly get the full CRS information from GDAL. However I couldn't
> see those CRSs from QGIS. Would you please test it out whether your
> QGIS contains EPSG code from 5167 to 5188?
In Lisboa standalone: no; in QGIS Master: yes (b9b943d, from November)
> I tested it with QGIS 1.9.0 Alpha master nightly build version on my
> Windows, Mac OSX and Ubuntu. And got the same result. And there is no
> blanks in installation folder name. For example on windows,
> c:\osgeo4w\... is my default folder name.  So I believe that this can
> be a bug of crssync.
> I tried to find postinstall.log but I couldn't.
Just saw that postinstall.log is only with standalone Windows version.
> However I found
> setup.log showing this kind of error.
> *** 2013/02/12 13:42:30 running: cmd.exe /c
> C:\OSGeo4W\etc\postinstall\sip.bat 2013/02/12 13:42:30 running:
> cmd.exe /c C:\OSGeo4W\etc\postinstall\qgis-dev.bat 2013/02/12
> 13:42:32 abnormal exit: exit code=-1073741511 2013/02/12 13:43:52
> note: Installation Complete ***
> Any idea on this?
Well, thats not normal, and might be the reason for not syncing. There
is also a setup.log.full, which might give further information at this
points.
Anyway, your ticket on hub.qgis.org should be updated. It has nothing to
do with new or old EPSG codes.
Greetings,
André Joost
