[Qgis-developer] Print composer: dimensions of arrow/line objects
Larry Shaffer larrys at dakotacarto.com
Wed Feb 20 09:15:17 PST 2013
Hi Andreas,
I noticed the same issue when testing Olivier's GUI changes. Tested on 1.8
and it exists there as well. Seems to be the only item whose position input
is not functioning properly, so probably a simple code fix. A bit odd,
though, since one would expect such a transform to be abstracted out of the
individual composer item code (maybe it is). Please make an issue ticket,
if you have the time.
Larry
On Wed, Feb 20, 2013 at 9:23 AM, Andreas Neumann <a.neumann at carto.net>wrote:
> There is also a strange behaviour with arrow elements.
> If one explicitly sets the lines to a certain width. Say I set a
> horizontal line to a width of 130 (through "Position and Size"), then QGIS
> replaces this value by a value of 130.001 or sometimes to 129.999 or so. Is
> there a reason for this behaviour? I think it is quite disturbing if one
> explictly sets a value and then QGIS uses something else - even if the
> value is very close to my original value. Is this sort of a rounding
> problem or a bounding box problem?
> I think this problem existed for a long time already - maybe even from the
> beginning when the arrow object was introduced.
> Thanks if anyone knows how to correct this behaviour.
> Andreas
> Andreas Neumann
> Böschacherstrasse 10A
> 8624 Grüt (Gossau ZH)
> Switzerland
> ______________________________**_________________
> Qgis-developer mailing list
> http://lists.osgeo.org/**mailman/listinfo/qgis-**developer<http://lists.osgeo.org/mailman/listinfo/qgis-developer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130220/9f453d4b/attachment.html>
