[Qgis-developer] New OpenStreetMap integration
Denis Rouzaud denis.rouzaud at gmail.com
Thu Feb 28 22:50:24 PST 2013
Hi Martin,
I got this error when I compile this morning.
http://pastebin.com/v0WPVbj7
 1.
    /home/denis/opt/qgis/Quantum-GIS/build-master/python/core/sipcorepart3.cpp:
    In function 'PyObject*
    meth_QgsFeatureRequest_setFilterFid(PyObject*, PyObject*)':
 2.
    /home/denis/opt/qgis/Quantum-GIS/build-master/python/core/sipcorepart3.cpp:42358:47:
    error: no matching function for call to
    'QgsFeatureRequest::setFilterFid(QString&)'
 3.
    note: candidate is:
 4.
    /home/denis/opt/qgis/Quantum-GIS/python/../src/core/qgsfeaturerequest.h:85:24:
    note: QgsFeatureRequest& QgsFeatureRequest::setFilterFid(QgsFeatureId)
 5.
    note:   no known conversion for argument 1 from 'QString' to
    'QgsFeatureId {aka long long int}'
Not sure it is related to the OSM integration.
Do you have any tip?
Thanks a lot,
Denis
On 02/28/2013 10:35 PM, Martin Dobias wrote:
> Hi all
> so finally I have pushed my initial work on OpenStreetMap integration
> to master... d'oh I have missed The Open Data Day (Feb 23) by few
> days! The idea is to completely replace the current OpenStreetMap
> provider and plugin. As announced in the list before, the new OSM
> support is read-only and right now I have no plans to add editing
> functionality. Editing would mean a _lot_ of work - map tools,
> tracking of changes, conflict resolution - and there are already great
> programs for editing OSM data.
> If you would like to test the new stuff, go to menu Vector >
> OpenStreetMap. No need to enable any plugins. The workflow should be:
> 0. get OSM XML file (from web or download in GUI)
> 1. import XML file to a SQLite topology database (once)
> 2. export SpatiaLite layers from topology with a fixed set of tags - attributes
> Integrated download uses Overpass API, so you should be able to
> download data from any extent size. The download server in GUI is
> currently fixed to overpass-api.de. When using download, make sure to
> set high timeout (Options > Network > Timeout for network requests) -
> currently there's a problem with QGIS network manager - it will time
> out after the fixed time even if the data is being continuously
> received.
> The work is by no means complete, there are various pieces missing,
> though it should be already usable. Some features I would like to add:
> - advanced download queries (e.g. filtering by tags)
> - filtering on export (e.g. export only railroads, only restaurants)
> - python bindings
> - support for relations
> - identification GUI (e.g. see all tags, even those not exported)
> There is a low-level API in qgis analysis library which should allow
> 3rd party tools/plugins do some work with OSM data (currently
> QgsOSMDownload, QgsOSMXmlImport and QgsOSMDatabase classes).
> Please let me know what do you think about it or if you encounter any bugs.
> I will be removing the OSM provider+plugin very soon. This is another
> piece from the master plan for removal of old symbology (OSM provider
> implements a renderer based on old symbology).
> Martin
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130301/f6b65b90/attachment.html>
