[Qgis-developer] New OpenStreetMap integration
Martin Dobias wonder.sk at gmail.com
Thu Feb 28 23:25:48 PST 2013
On Fri, Mar 1, 2013 at 5:45 AM, Mathieu Pellerin <nirvn.asia at gmail.com> wrote:
> Martin,
> Nice, glad the OSM download/import support is being worked on.
> I've just tried to import two OSM files: one which I had saved through JOSM,
> and the other one downloaded just now via your Download OSM Data dialogue.
> With both files, QGIS fails to import data with this error:
> Failed to import OSM data:
> Error executing SQL command:
> wrong number of arguments to function InitSpatialMetadata()
> SQL:
> SELECT InitSpatialMetadata('WGS84')
That's presumably the problem Borys had - should be fixed in master now.
Martin
