[Qgis-developer] Can we remove old labeling from the UI
Andreas Neumann a.neumann at carto.net
Sun Jun 9 05:36:48 PDT 2013
Marco Hugentobler is currently working on optimizing the labeling of
area features. Because it is feature-freeze I don't know if this will be
added to 2.0 or delayed for 2.1 - maybe the PSC can make a decision
about this.
Personally I would recommend to get rid of the old labeling now.
Andreas
Am 09.06.2013 12:47, schrieb Borys Jurgiel:
> The only thing I *REALLY* miss in the new labelling is an optional FAST method
> to put labels just in poligon centroids with ommiting any expensive collision
> algorithms. When just browsing data the speed is priority, I don't need
> beautiful map, I need to FAST put ANY labels to see what is in polygons.
> Unless it's not available in the new labelling, we make a regression, removing
> one of the most fundamental features. Please correct me if I'm missed some PAL
> option that I can disable to achieve a significant boost.
> Dnia niedziela, 9 czerwca 2013 o 12:13:01 MORREALE Jean Roc napisał(a):
>> What is the status ? Are we going to keep a deprecated label tab for the
>> next 3 years ?
>> Le 26/05/2013 14:37, Nathan Woodrow a écrit :
>>> Can we finally remove the old label UI from the layer properties dialog?
>>>   Could we remove it by default and just enable it for old project that
>>> have old labels defined.
>>> - Nathan
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
