[Qgis-developer] Can we remove old labeling from the UI
Tim Sutton lists at linfiniti.com
Sun Jun 9 10:28:21 PDT 2013
Hi
I also think we should hide the old labelling dialog. I think Larry
was working on migration logic that would allow old labels to be
converted to new. I cant remember if he kept this back for 2.1 though.
Assuming its not ready, we should follow Nathan's suggestion of hiding
the old labels tab unless the project file indicates it is needed.
PS optimisation wise couldnt we just have a 'quick' mode that draws a
maximum of n labels pre render?
Regards
Tim
On Sun, Jun 9, 2013 at 2:36 PM, Andreas Neumann <a.neumann at carto.net> wrote:
> Marco Hugentobler is currently working on optimizing the labeling of
> area features. Because it is feature-freeze I don't know if this will be
> added to 2.0 or delayed for 2.1 - maybe the PSC can make a decision
> about this.
> Personally I would recommend to get rid of the old labeling now.
> Andreas
> Am 09.06.2013 12:47, schrieb Borys Jurgiel:
>> The only thing I *REALLY* miss in the new labelling is an optional FAST method
>> to put labels just in poligon centroids with ommiting any expensive collision
>> algorithms. When just browsing data the speed is priority, I don't need
>> beautiful map, I need to FAST put ANY labels to see what is in polygons.
>> Unless it's not available in the new labelling, we make a regression, removing
>> one of the most fundamental features. Please correct me if I'm missed some PAL
>> option that I can disable to achieve a significant boost.
>> Dnia niedziela, 9 czerwca 2013 o 12:13:01 MORREALE Jean Roc napisał(a):
>>> What is the status ? Are we going to keep a deprecated label tab for the
>>> next 3 years ?
>>> Le 26/05/2013 14:37, Nathan Woodrow a écrit :
>>>> Can we finally remove the old label UI from the layer properties dialog?
>>>>   Could we remove it by default and just enable it for old project that
>>>> have old labels defined.
>>>> - Nathan
>>> Qgis-developer mailing list
>>> Qgis-developer at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton - QGIS Project Steering Committee Member (Release  Manager)
Please do not email me off-list with technical
support questions. Using the lists will gain
more exposure for your issues and the knowledge
surrounding your issue will be shared with all.
Visit http://linfiniti.com to find out about:
 * QGIS programming and support services
 * Mapserver and PostGIS based hosting plans
 * FOSS Consulting Services
Skype: timlinux
Irc: timlinux on #qgis at freenode.net
