[Qgis-developer] Dev plugin for master
Werner Macho werner.macho at gmail.com
Wed Jun 26 05:19:03 PDT 2013
There is no 2.0 version right now ..
IIRC minimum version right now (to be able to use it in master) should be
1.9)
hope this solves your problem
kind regards
Werner
On Wed, Jun 26, 2013 at 2:01 PM, PIERRE Sylvain <sylvain.pierre at cg67.fr>wrote:
> Hi,****
> I’m trying to develop a small plugin for master.****
> I have set qgisMinimumVersion to 2.0 and stored the plugin in
> .qgis2\python\plugins but running  Qgis does :****
> *This plugin is incompatible with this version of QGIS*
> Plugin designed for QGIS 1.x****
> *ThemeManager*****
> Installed version: ? (in
> C:/Users/sylvain.pierre/.qgis2/python/plugins/ThemeManager)****
> What should be the solution?****
> Thanks****
> *→*  *Sylvain PIERRE*
>          Ingénieur Géographe****
>          Adjoint au chef du service****
>          Direction de l’Agriculture, de l’Espace Rural et de
> l’Environnement****
>          Service Administration Générale****
>        *Conseil Général du Bas-Rhin*
> [image: Description : Description :
> \\dsi7085103\c$\Users\samuel.guigon\Pictures\CG67\logo_CG67+www_coul.jpg]<http://www.bas-rhin.fr/>
>          Passerelle 67
>          20 rue Livio / 67000 Strasbourg
>          Tél : +33 3 88 76 68 88 – mobile :
>          Fax : 03 88 76 68 71
>          Email : sylvain.pierre at cg67.fr****
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20130626/5736574a/attachment.html>
