[Qgis-developer] QGIS 2.0 and GRASS integration on OSX and Windows
William Kyngesburye woklist at kyngchaos.com
Mon Sep 23 17:15:18 PDT 2013
For the Mac side, I found a library link error.  I'll fix this for an update soon.
The msys setting is ignored on OS X (and Linux).  Maybe this should be shown only to Windows users so everyone else is not confused.
On Sep 23, 2013, at 3:55 PM, Andreas Neumann wrote:
> Hi all,
> I know that this is probably a known-issue.
> We downloaded and installed the latest QGIS and GDAL packages from
> Kyngchaos. The package includes GRASS, but the processing integration
> does not work. Is there something that needs to be configured in
> addition to get it working?
> I checked the /Applications/QGIS.app/Contents/MacOS folder and GRASS
> seems to be present. Processing finds the GRASS modules - they are
> listed in the toolbox. However, if we open a module, e.g. v.surf.rst we
> get the error message that GRASS is missing or not configured properly.
> See http://webgis.uster.ch/temp/grass_missing_dependency.png
> In the configuration panel, the settings to the GRASS folder is correct
> and it exists, however there is no MSYS available in QGIS on OSX. See
> http://webgis.uster.ch/temp/grass_processing_settings.png - so the given
> path /Applications/QGIS.app/Contents/msys is in fact not existing.
> Most of our Windows users seem to get a very similar behavior.
> Juliana has a course on Thursday and we would appreciate it very much if
> we could find a solution until then.
> Thank you for your help to get this working.
> Andreas and Juliana
> Qgis-developer mailing list
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
Theory of the Universe
There is a theory which states that if ever anyone discovers exactly what the universe is for and why it is here, it will instantly disappear and be replaced by something even more bizarrely inexplicable.  There is another theory which states that this has already happened.
-Hitchhiker's Guide to the Galaxy 2nd season intro
