[Qgis-developer] different projects, same layers IDs
Giovanni Manghi giovanni.manghi at faunalia.pt
Wed Apr 16 03:59:36 PDT 2014
Hi all,
sometimes it is necessary to create and publish with qgis server
multiple projects, that are made from the same template containing a
bunch of layers that are the same in all projects. IDs for this layers
are the same, then on qgis server issues happens
http://hub.qgis.org/issues/7956
http://hub.qgis.org/issues/10068
as suggested here
http://hub.qgis.org/issues/7956#note-5
it seems that adding the project name to the actual layers id seems a
good and easy solution.
I was remembering that there was a patch/pull request about it, but
can't find it.
cheers!
Giovanni Manghi
Faunalia.pt
Sistemas de Informação Geográfica Open Source
Portugal
Web: http://www.faunalia.pt
Email & Jabber: giovanni.manghi at faunalia.pt
PGP Key available
Tel. + 351 96 7058216
