[Qgis-developer] Building and running qgis from master
Werner Macho werner.macho at gmail.com
Tue Aug 5 15:01:04 PDT 2014
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi!
Thanks for reminding me to use make test on master from time to time ..
currently:
82% tests passed, 17 tests failed out of 97
(building on 64 Bit Linux Mint Debian Edition)
I do not wonder that some tests fail in master, and I also know that I
never was at 100% but 54 tests fail is a bit too much.Exit here is
without SEGFAULT ..
I guess there is something wrong/missing on your system.
without any further information (I am also running and compiling it on
Ubuntu 14.04 - no info about Kubuntu) it is a bit hard to tell anything.
Is Kubuntu 14.04 probably using Qt5 already?
kind regards
Werner
On 08/05/2014 11:12 PM, Jarl Friis wrote:
> Hi QGis developers.
> I was considering hacking a bit on qgis...
> I cloned it from github and building (on Kubuntu 14.04) the master
> branch.
> when running `make test` I get 44% tests passed, 54 tests failed
> out of 97
> Is this expected?
> Further, when I launch qgis and exits without doing anything, it
> crashes with SEGFAULT.
> Jarl _______________________________________________ Qgis-developer
> mailing list Qgis-developer at lists.osgeo.org
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.15 (GNU/Linux)
Comment: Using GnuPG with Thunderbird - http://www.enigmail.net/
iEYEARECAAYFAlPhVB0ACgkQDAH1YiCxBglizwCbBSpsz0Ie3y3E1zd3BVudFpCN
KLcAnA8lJlAmLHpV1NzF7zIcXUK71zL+
=NExe
-----END PGP SIGNATURE-----
