[Qgis-developer] Building and running qgis from master
Jarl Friis
jarl at softace.dk
Wed Aug 6 00:30:23 PDT 2014
Hi Werner.
Thanks for replying.
2014-08-06 0:01 GMT+02:00 Werner Macho <werner.macho at gmail.com>:
> Hi!
> Thanks for reminding me to use make test on master from time to time ..
> currently:
> 82% tests passed, 17 tests failed out of 97
> (building on 64 Bit Linux Mint Debian Edition)
> I do not wonder that some tests fail in master, and I also know that I
> never was at 100% but 54 tests fail is a bit too much.Exit here is
> without SEGFAULT ..
I have quite a lof of SEGFAULTS.
> I guess there is something wrong/missing on your system.
> without any further information (I am also running and compiling it on
> Ubuntu 14.04 - no info about Kubuntu) it is a bit hard to tell anything.
Kubuntu is just Ubuntu with another default package selection (KDE
instead of Gnome/Unity), so consider it as Ubuntu.
> Is Kubuntu 14.04 probably using Qt5 already?
No, I am compiling against Qt 4.8.5 (the latest Ubuntu package)
The test results are:
44% tests passed, 54 tests failed out of 97
Total Test time (real) = 412.50 sec
The following tests FAILED:
3 - qgis_applicationtest (SEGFAULT)
4 - qgis_diagramtest (OTHER_FAULT)
5 - qgis_diagramexpressiontest (SEGFAULT)
6 - qgis_expressiontest (SEGFAULT)
9 - qgis_regression992 (OTHER_FAULT)
10 - qgis_regression1141 (SEGFAULT)
11 - qgis_rasterlayertest (OTHER_FAULT)
12 - qgis_rastersublayertest (OTHER_FAULT)
13 - qgis_rasterfilewritertest (SEGFAULT)
15 - qgis_maplayertest (SEGFAULT)
16 - qgis_rendererstest (OTHER_FAULT)
17 - qgis_maprenderertest (OTHER_FAULT)
18 - qgis_blendmodestest (OTHER_FAULT)
19 - qgis_geometrytest (Failed)
20 - qgis_coordinatereferencesystemtest (SEGFAULT)
22 - qgis_vectordataprovidertest (SEGFAULT)
23 - qgis_vectorlayertest (OTHER_FAULT)
24 - qgis_rulebasedrenderertest (SEGFAULT)
25 - qgis_ziplayertest (SEGFAULT)
26 - qgis_dataitemtest (SEGFAULT)
28 - qgis_composerutils (OTHER_FAULT)
29 - qgis_composerpapertest (OTHER_FAULT)
30 - qgis_composermaptest (OTHER_FAULT)
31 - qgis_composereffectstest (OTHER_FAULT)
32 - qgis_composershapestest (OTHER_FAULT)
33 - qgis_composerrotationtest (OTHER_FAULT)
34 - qgis_composerpicturetest (OTHER_FAULT)
35 - qgis_atlascompositiontest (OTHER_FAULT)
36 - qgis_composerlabeltest (SEGFAULT)
37 - qgis_composertabletest (SEGFAULT)
38 - qgis_composerddtest (SEGFAULT)
39 - qgis_stylev2test (SEGFAULT)
40 - qgis_composerhtmltest (Failed)
42 - qgis_composerscalebartest (OTHER_FAULT)
44 - qgis_vectorlayercachetest (SEGFAULT)
46 - qgis_gradienttest (OTHER_FAULT)
47 - qgis_shapebursttest (OTHER_FAULT)
48 - qgis_invertedpolygontest (OTHER_FAULT)
49 - qgis_zoomtest (SEGFAULT)
50 - qgis_projectionissues (SEGFAULT)
51 - qgis_scalecombobox (SEGFAULT)
52 - qgis_dualviewtest (OTHER_FAULT)
53 - qgis_rubberbandtest (SEGFAULT)
55 - qgis_analyzertest (SEGFAULT)
57 - qgis_zonalstatisticstest (OTHER_FAULT)
58 - qgis_wcsprovidertest (SEGFAULT)
61 - PyQgsLocalServer (Failed)
69 - PyQgsBlendModes (Failed)
78 - PyQgsComposerHtml (Failed)
84 - PyQgsSymbolLayerV2 (Failed)
86 - PyQgsAtlasComposition (Failed)
90 - PyQgsPalLabelingCanvas (Failed)
91 - PyQgsPalLabelingComposer (Failed)
92 - PyQgsPalLabelingServer (Failed)
Errors while running CTest
Now that you are compiling and building on Ubuntu 14.04 64bit, Could
you send me your CMakeCache.txt from that system? So that I can
investigate the build configuration difference.
Jarl
