[Qgis-developer] After upgrade all fields are editable in QGIS project file
Matthias Kuhn matthias.kuhn at gmx.ch
Wed Aug 6 23:05:27 PDT 2014
Hi Markus,
Are you able to switch them back to non-editable? Somebody reported
issues that he is not able to turn editing off [1].
If you open your old files with the current development version, does
the same happen? IIRC jef made some changes that could have fixed this.
Best regards,
Matthias
[1] http://hub.qgis.org/issues/10899
On 06.08.2014 09:10, Markus Innerebner wrote:
> Hi all
> I post this question in the developer mailing list, since I did not get
> any answer in the user mailing list.
> This is the behavior in the application after upgrading:
> I realized after the upgrade from Valmeira to version Chugiak in my QGIS
> project all fields that before were not editable now are editable. Does
> someone else have the same problem?
> kind regards
> Markus
> Qgis-developer mailing list
