[Qgis-developer] QGIS server ignores optional SVG symbols path
kimaidou kimaidou at gmail.com
Tue Aug 26 07:44:21 PDT 2014
Thanks for this solution. Is there a place where all the configuration
options are listed and explained ?
* QGIS Server Environment variables like :
QGIS_OPTIONS_PATH
I am sure there are some more.
* Qgis configuration file variables to put in the .ini , like
[svg]
searchPathsForSVG=/path/to/svg1|/path/to/svg2
I searched the documentation with "configuration" key, and had a look at
[1] but could not find it.
[1]
http://docs.qgis.org/2.2/en/docs/user_manual/working_with_ogc/ogc_server_support.html?highlight=server
Thanks in advance
Michael
2014-08-15 14:41 GMT+02:00 Andrea Peri <aperi2007 at gmail.com>:
> Of course. We are using iT just now from 2.4 qgis.server.
>  Il 15/ago/2014 13:02 "Alessandro Pasotti" <apasotti at gmail.com> ha
> scritto:
> Thank you, is this feature already available in 2.4.0 ?
>> 2014-08-14 20:01 GMT+02:00 aperi2007 <aperi2007 at gmail.com>:
>> > I guess the issue was resolved.
>> > Look at this tickets.
>> > http://hub.qgis.org/issues/10327
>> > and this
>> > http://hub.qgis.org/issues/8664
>> > You should define one or more environment variables.
>> > for path.
>> > We use this approach succesfully.
>> > A.
>> > Il 14/08/2014 17:54, Alessandro Pasotti ha scritto:
>> >> Hi,
>> >> I noticed that when I use SVG symbols located in an optional path as
>> >> set in "Settings->Options->System->SVG Paths" the symbols are not
>> >> found from QGIS server.
>> >> The solution would be to add such information (currently missing) to
>> >> the project file, because this is mandatory for the server to locate
>> >> the symbols.
>> >> Should I file a ticket?
>> Alessandro Pasotti
>> w3:   www.itopen.it
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140826/b971db78/attachment-0001.html>
