[Qgis-developer] EPSG codes
Andre Joost andre+joost at nurfuerspam.de
Fri Dec 12 21:52:03 PST 2014
Am 12.12.2014 um 22:14 schrieb Trevor Wiens:
> Andre I believe you misunderstood what I'm saying. The version of gdal does
> not appear to affect the presence of EPSG:6148 in srs.db
> Box 1:
> debian wheezy
> QGIS 2.4
> gdal 1.9
> ESPG:6148 in the srs.db
> ESPG6148 NOT in gdal csv files
> Box 2:
> debian wheezy
> QGIS 2.6.1
> gdal 1.9
> ESPG:6148 NOT in srs.db
> ESPG:6148 NOT in gdal csv files
> This issue is clearly more complex than the gdal version.
I don't understand your logic. Both Boxes have gdal 1.9, both missing
EPSG:6148. It is crssync that pushes the GDAL definition into srs.db.
Looking at the Windows installations of gisinternals and QGIS
standalone, I find the EPSG code inserted between
GDAL 1.10.1 and 1.11.0, published 05/2013 vs 04/2014
QGIS 2.2.0 and 2.4.0, published 02/2014 vs 06/2014
QGIS Linux packages don't include gdal, so it is up to you to get the
recent GDAL version (unless it is updated as dependency).
Greetings,
André Joost
