[Qgis-developer] EPSG codes
Trevor Wiens
tsw.web at gmail.com
Fri Dec 12 22:29:41 PST 2014
I don't understand it either; I'm not in any way suggesting it makes sense.
I'm simply describing how it is.
The confusing state of my machines suggests that crssync may do other
things than just use the GDAL sources to populate srs.db. Is that mistaken?
I haven't looked at the source for crssync; do you know for certain that it
only scans the gdal csv files?
The point the original question poster made and which I verified was that
with QGIS 2.4 on Linux, EPSG:6148 was present and supported; an upgrade to
2.6.1 removes it. I don't how or why. Again, my machines suggests that this
is more than a GDAL library issue.
TSW
On Fri, Dec 12, 2014 at 10:52 PM, Andre Joost <andre+joost at nurfuerspam.de>
wrote:
> Am 12.12.2014 um 22:14 schrieb Trevor Wiens:
>> Andre I believe you misunderstood what I'm saying. The version of gdal
>> does
>> not appear to affect the presence of EPSG:6148 in srs.db
>> Box 1:
>> debian wheezy
>> QGIS 2.4
>> gdal 1.9
>> ESPG:6148 in the srs.db
>> ESPG6148 NOT in gdal csv files
>> Box 2:
>> debian wheezy
>> QGIS 2.6.1
>> gdal 1.9
>> ESPG:6148 NOT in srs.db
>> ESPG:6148 NOT in gdal csv files
>> This issue is clearly more complex than the gdal version.
> I don't understand your logic. Both Boxes have gdal 1.9, both missing
> EPSG:6148. It is crssync that pushes the GDAL definition into srs.db.
> Looking at the Windows installations of gisinternals and QGIS standalone,
> I find the EPSG code inserted between
> GDAL 1.10.1 and 1.11.0, published 05/2013 vs 04/2014
> QGIS 2.2.0 and 2.4.0, published 02/2014 vs 06/2014
> QGIS Linux packages don't include gdal, so it is up to you to get the
> recent GDAL version (unless it is updated as dependency).
> Greetings,
> André Joost
> Qgis-developer mailing list
Trevor Wiens
Apropos Information Systems
aproposinfosystems.com
Calgary, Alberta
Ph. 403-973-5901
Fax 780-666-4580
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141212/e1487dd1/attachment.html>
