[Qgis-developer] Localizing QGIS Server
Ziegler Stefan Stefan.Ziegler at bd.so.ch
Wed Dec 17 07:18:53 PST 2014
Hi Andi
I have mine (Ubuntu 10.04) in /etc/apache2/mod-enabled/fcgid.conf:
  FcgidInitialEnv LANG=de_CH.UTF-8
But this did not work on another Ubuntu 10.04 machine. We had set the variable per process:
  FcgidCmdOptions /opt/wwwroot/cgi-bin/qgis_mapserv.fcgi \
    InitialEnv LANG=de_CH \
    IOTimeout 180 \
    MinProcesses 6 \
    MaxProcesses 6
Best regards
Stefan
> -----Ursprüngliche Nachricht-----
> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
> Gesendet: Mittwoch, 17. Dezember 2014 15:51
> An: qgis-developer
> Betreff: [Qgis-developer] Localizing QGIS Server
> Hi,
> I have a minor problem with QGIS Server. When printing, the numeric scale shows the
> thousand separator at the bottom with a comma (",") instead of at the top, like we use
> it normally in Switzerland ("'").
> I tried setting the LC_NUMERIC variable to de_CH.utf8, but this did not help. Do you
> know which variable I need to set to influence the display of the thousand separator in
> QGIS?
> I did my variable definition in /etc/apache2/mods-enabled/env.conf by adding the lines
> SetEnv LC_NUMERIC "de_CH.utf8"
> SetEnv LANGUAGE "de_CH.utf8"
> Thank you in advance for any hints!
> Andreas
> Qgis-developer mailing list
