[Qgis-developer] Localizing QGIS Server
Andreas Neumann
a.neumann at carto.net
Wed Dec 17 07:40:38 PST 2014
Hi Stefan,
Thanks - setting it in /etc/apache2/mod-enabled/fcgid.conf
with
FcgidInitialEnv LC_NUMERIC=de_CH.utf8
worked fine.
I forgot about the separate location for environment variables for
FCGID. It is quite strange that fcgi processes have their own env vars
compared to the rest of Apache - but anyway. It worked.
Thanks again,
Andreas
Am 2014-12-17 16:18, schrieb Ziegler Stefan:
> Hi Andi
> I have mine (Ubuntu 10.04) in /etc/apache2/mod-enabled/fcgid.conf:
> FcgidInitialEnv LANG=de_CH.UTF-8
> But this did not work on another Ubuntu 10.04 machine. We had set the
> variable per process:
> FcgidCmdOptions /opt/wwwroot/cgi-bin/qgis_mapserv.fcgi \
> InitialEnv LANG=de_CH \
> IOTimeout 180 \
> MinProcesses 6 \
> MaxProcesses 6
> Best regards
> Stefan
>> -----Ursprüngliche Nachricht-----
>> Von: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-
>> bounces at lists.osgeo.org] Im Auftrag von Andreas Neumann
>> Gesendet: Mittwoch, 17. Dezember 2014 15:51
>> An: qgis-developer
>> Betreff: [Qgis-developer] Localizing QGIS Server
>> Hi,
>> I have a minor problem with QGIS Server. When printing, the numeric
>> scale shows the
>> thousand separator at the bottom with a comma (",") instead of at the
>> top, like we use
>> it normally in Switzerland ("'").
>> I tried setting the LC_NUMERIC variable to de_CH.utf8, but this did
>> not help. Do you
>> know which variable I need to set to influence the display of the
>> thousand separator in
>> QGIS?
>> I did my variable definition in /etc/apache2/mods-enabled/env.conf by
>> adding the lines
>> SetEnv LC_NUMERIC "de_CH.utf8"
>> SetEnv LANGUAGE "de_CH.utf8"
>> Thank you in advance for any hints!
>> Andreas
>> Qgis-developer mailing list
>> Qgis-developer at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/qgis-developer
