[Qgis-developer] Plugins approval
Jonathan Moules jonathanmoules at warwickshire.gov.uk
Tue Jan 7 05:29:49 PST 2014
>  I remember, I discussed another key "website" with Borys, which would be
> shown in a frame in the plugin description page. This could be used to show
> even pictures in a description. Or we could just embed the URL listed in
> homepage.
If I'm understanding correctly, you're proposing that the explanations etc
be hosted online? From what I've picked up reading the lists and elsewhere,
QGIS is used in quite a few instances in locations where internet access is
lacking or merely unreliable. I think any help/explanation should be
integrated and distributed with the software.
So I would not say "anything to fix that" is a good approach
A poor choice of words on my part. Obviously a good fix is preferable to.
Cheers,
Jonathan
This transmission is intended for the named addressee(s) only and may
contain sensitive or protectively marked material up to RESTRICTED and
should be handled accordingly. Unless you are the named addressee (or
authorised to receive it for the addressee) you may not copy or use it, or
disclose it to anyone else. If you have received this transmission in error
please notify the sender immediately. All email traffic sent to or from us,
including without limitation all GCSX traffic, may be subject to recording
and/or monitoring in accordance with relevant legislation.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140107/6288cbea/attachment-0001.html>
