[Qgis-developer] New Save as... dialog
Anita Graser anitagraser at gmx.at
Thu Jan 16 12:28:17 PST 2014
Am 16.01.2014, 20:15 Uhr, schrieb Werner Macho <werner.macho at gmail.com>:
> If GDAL is extended with new options not available in the
> preselectable options (or you have your own newer version of GDAL
> installed) there is always the possibility to enter these new options
> manual in these boxes (sometimes the commands can be quite long -
> hence the space to overlook the full command). If you know a way of
> hiding these boxes (again - more options should not be necessary to be
> opened) it would be nice to make them smaller .. I did find no way.
>> + 1 for no empty collapsible boxes.
> which will mean that we loose functionality
I think we might not be talking about the same thing here.
Check http://www.faunalia.eu/~paolo/vector.png
"Datasource Options" and "Layer Options" are empty and could be hidden.
"Custom Options" contains two input fields for custom layer and datasource
options. Those are fine!
Best wishes,
Anita
anitagraser.com
