[Qgis-developer] New Save as... dialog
Werner Macho werner.macho at gmail.com
Thu Jan 16 12:37:54 PST 2014
Ok .. Now I know what you mean ..
Hide it if there is nothing inside..
I see
On Thu, Jan 16, 2014 at 10:28 PM, Anita Graser <anitagraser at gmx.at> wrote:
> Am 16.01.2014, 20:15 Uhr, schrieb Werner Macho <werner.macho at gmail.com>:
>> If GDAL is extended with new options not available in the
>> preselectable options (or you have your own newer version of GDAL
>> installed) there is always the possibility to enter these new options
>> manual in these boxes (sometimes the commands can be quite long -
>> hence the space to overlook the full command). If you know a way of
>> hiding these boxes (again - more options should not be necessary to be
>> opened) it would be nice to make them smaller .. I did find no way.
>>> + 1 for no empty collapsible boxes.
>> which will mean that we loose functionality
> I think we might not be talking about the same thing here.
> Check http://www.faunalia.eu/~paolo/vector.png
> "Datasource Options" and "Layer Options" are empty and could be hidden.
> "Custom Options" contains two input fields for custom layer and datasource
> options. Those are fine!
> Best wishes,
> Anita
> anitagraser.com
