[Qgis-developer] processing.runalg() issue with grass algorithms
Eric Goddard egoddard1010 at gmail.com
Mon Mar 24 20:13:27 PDT 2014
Oops, my mistake. I have ##lrm=output raster in the header, but lpf = ...
Is the only line in my code.
I don't get the error message after changing lrm to lpf in the header. I do
get another error message, but I think I broke my processing by trying to
force an update. I'll test it tomorrow. Sorry about the confusion!
Eric
On Mar 22, 2014 5:06 PM, "Eric Goddard" <egoddard1010 at gmail.com> wrote:
> Ah, I didn't know a file could he specified without a path. Thanks for the
> clarification!
> On Mar 22, 2014 4:37 PM, "Victor Olaya" <volayaf at gmail.com> wrote:
>> > If I run the same line in the python console, it works correctly:
>> >>>> radius = 4
>> >>>> lpf = processing.runalg("saga:simplefilter", "SR_50M_alaska_nad", 0,
>> 0, radius, None)
>> >>>> processing.load(lpf['RESULT'])
>> > Results in the map being loaded.
>> Not sure why this is happening. I will try to reproduce the error and
>> see if it can be fixed
>> Thanks for the report
>> > Also, if I change the output folder in the processing settings to a
>> > different location (in this case, tmp/processing in my home folder)
>> > and run another algorithm in the python console, the RESULT key still
>> > points to /tmp/processing/...
>> This is not a bug. If you do not enter a filename, the output will
>> always go to a temporary file. The output folder that yu can set in
>> the settings  is the folder to be used when you enter a filename
>> without a path (like "myfile.shp", but not "/home/myuser/myfile.shp"),
>> not the folder to use for temporary files.
>> Thanks again!
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140324/2ccd0918/attachment.html>
