[Qgis-developer] processing.runalg() issue with grass algorithms
Eric Goddard egoddard1010 at gmail.com
Tue Mar 25 14:36:14 PDT 2014
Alright, latest master (9e42c5b), with processing version
2.0-20131120. Running a custom tool that consists of the following
code results in an error:
##dem=raster
##radius=number 4
##lpf=output raster
lpf = processing.runalg("saga:simplefilter", dem, 0, 0, radius, None)
An error has occured while executing Python code:
  File "/home/eric/.qgis2/python/plugins/processing/gui/AlgorithmExecutionDialog.py",
line 256, in accept
    self.finish()
line 281, in finish
    Postprocessing.handleAlgorithmResults(self.alg, self, not keepOpen)
  File "/home/eric/.qgis2/python/plugins/processing/gui/Postprocessing.py",
line 77, in handleAlgorithmResults
    dlg = CouldNotLoadResultsDialog(wrongLayers, alg)
  File "/home/eric/.qgis2/python/plugins/processing/gui/CouldNotLoadResultsDialog.py",
line 41, in __init__
    self.setupUi()
line 50, in setupUi
    html = self.alg.getPostProcessingErrorMessage(self.wrongLayers)
  File "/home/eric/.qgis2/python/plugins/processing/core/GeoAlgorithm.py",
line 520, in getPostProcessingErrorMessage
    + layer.value + '\n'
TypeError: cannot concatenate 'str' and 'dict' objects
Python version:
2.7.6 (default, Feb 26 2014, 12:07:17)
[GCC 4.8.2 20140206 (prerelease)]
QGIS version:
2.3.0-Master Master, 9e42c5b
Python path: ['/home/eric/.qgis2/python/plugins/processing',
'/usr/share/qgis/python', u'/home/eric/.qgis2/python',
u'/home/eric/.qgis2/python/plugins', '/usr/share/qgis/python/plugins',
'/usr/lib/python27.zip', '/usr/lib/python2.7',
'/usr/lib/python2.7/plat-linux2', '/usr/lib/python2.7/lib-tk',
'/usr/lib/python2.7/lib-old', '/usr/lib/python2.7/lib-dynload',
'/usr/lib/python2.7/site-packages',
'/usr/lib/python2.7/site-packages/gtk-2.0',
'/usr/lib/python2.7/site-packages/wx-3.0-gtk2',
'/usr/share/qgis/python/plugins/fTools/tools', '/home/eric/Documents']
Running the code in the console completes successfully. However, I'm
still unable to run a grass algorithm when the grass_region_parameter
and grass_region_cellsize_parameter are set to None.
Thanks,
Eric
On Mon, Mar 24, 2014 at 10:13 PM, Eric Goddard <egoddard1010 at gmail.com> wrote:
> Oops, my mistake. I have ##lrm=output raster in the header, but lpf = ... Is
> the only line in my code.
> I don't get the error message after changing lrm to lpf in the header. I do
> get another error message, but I think I broke my processing by trying to
> force an update. I'll test it tomorrow. Sorry about the confusion!
> Eric
> On Mar 22, 2014 5:06 PM, "Eric Goddard" <egoddard1010 at gmail.com> wrote:
>> Ah, I didn't know a file could he specified without a path. Thanks for the
>> clarification!
>> On Mar 22, 2014 4:37 PM, "Victor Olaya" <volayaf at gmail.com> wrote:
>>> > If I run the same line in the python console, it works correctly:
>>> >>>> radius = 4
>>> >>>> lpf = processing.runalg("saga:simplefilter", "SR_50M_alaska_nad", 0,
>>> >>>> 0, radius, None)
>>> >>>> processing.load(lpf['RESULT'])
>>> > Results in the map being loaded.
>>> Not sure why this is happening. I will try to reproduce the error and
>>> see if it can be fixed
>>> Thanks for the report
>>> > Also, if I change the output folder in the processing settings to a
>>> > different location (in this case, tmp/processing in my home folder)
>>> > and run another algorithm in the python console, the RESULT key still
>>> > points to /tmp/processing/...
>>> This is not a bug. If you do not enter a filename, the output will
>>> always go to a temporary file. The output folder that yu can set in
>>> the settings  is the folder to be used when you enter a filename
>>> without a path (like "myfile.shp", but not "/home/myuser/myfile.shp"),
>>> not the folder to use for temporary files.
>>> Thanks again!
