[Qgis-developer] [Plugin presentation] LayerBender
Denis Rouzaud denis.rouzaud at gmail.com
Mon May 26 22:51:50 PDT 2014
Hi Olivier,
Once more, you did a really great job!
I just wonder about the technique when you have enough points (>7).
In case of mathcing old to new plans, isn't it better to do an affine
transformation (scale, translation and rotation) using least-squares
rather than doing a triangulation?
You might have better visual results with the triangulation, but the
affine would lead to more coherent results.
Cheers,
Denis
On 26.05.2014 21:18, Olivier Dalang wrote:
> Dear lists,
> I'm happy to present my new plugin called "LayerBender".
> It's purpose is to allow to align/distort vector layers to match a
> source, very much like georefencer does for raster. It seems ArcGIS
> and OpenJump call this feature "Rubber sheeting".
> Demonstration video : https://vimeo.com/96142479
> I needed this in a project I'm working on to align some already
> digitized historical maps.
> Please note that the plugin is still experimental and not much tested
> yet (and only under windows)... So please be understanding in case of
> problems !
> All feedback is welcome, either here or on
> https://github.com/olivierdalang/VectorBender
> Hope you like it !
> Best,
> Olivier
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20140527/3dd5c11d/attachment.html>
