[Qgis-developer] 2.6: first overview
Werner Macho werner.macho at gmail.com
Sun Nov 2 14:29:51 PST 2014
Hi!
Regarding translation it is now easier than ever before to contribute
and change the things yourself.
Just get an account on transifex [0] and apply for the italian
language - search for the typos and change them by yourself. That way
you make sure the correct string will find it's way into the next
release.
kind regards
Werner
[0] https://www.transifex.com/projects/p/QGIS
On Sun, Nov 2, 2014 at 11:11 PM, Niccolò Marchi
<sciurusurbanus at hotmail.it> wrote:
> Hi all,
> just few things I'm experiencing with 2.6:
> Attribute Table: modifying the content of a cell, it needs to save and
> reopen the table to see it updated...normal behaviour?
> Crash: different types. Usually closing the project, QGIS ends up with a
> minidump or the MS error window "The software stopped to work etc etc". This
> happens closing .qgs from 2.2 with or without saving to 2.6 version.
> Sometimes also while working. Attached you can find the .dmp (shall I upload
> them? I don't know how to deal with). Actually it's a quite annoying
> issue...
> Corrupt layers: the table appears but double-clicking the source it doesn't
> open the explorer as in 2.2; it only allows to modify the folder destination
> as text. Is that the new behavior?
> Translation (ITA): just few oversights:
> color selection panel: "incolla collore"
> modify widget properties: "il widget di modica può..."
> Is there anyone with the same issues? I'm working with W8.1 64bit and QGIS
> standalone.
> As always: thank you all for your work!
> All the best,
> Nic
> Qgis-developer mailing list
