[Qgis-developer] FW: Support | Custom install for XenApp | Removing menu options
Steven Campbell s.campbell at poole.gov.uk
Tue Nov 11 06:44:46 PST 2014
I've been trying to remove some functions from QGIS so we can deploy a stripped down version of it into a Citrix - XenApp 6.5 environment.
I've posted on the QGIS forum<http://gis.stackexchange.com/questions/120199/qgis-deployment-in-citrix-xenapp-how-to-remove-pyramids-from-the-image-proper> to see if anyone could help me with this set-up.
I need to remove the ability to build pyramids on QGIS when it is installed in XenApp (GIS team will use PC's to do rendering\pyramids overviews etc).  I can use the customization tool built in QGIS to remove the Menu options, however I need to remove the 'Properties' (or just the Pyramids) option from the context menu when you right click on an Image.
Here is an image of what I am trying to remove:
[cid:image001.png at 01CFFCFD.37FD8240]                         [cid:image004.jpg at 01CFFCFE.6F437BA0]
I need to prevent this option from being used on our XenApp environment due to the amount of memory it grabs.  If a user runs this on a highly loaded server it could cause outage for the other users on that server, if possible I'd like to configure GIS to avoid the option being used by mistake.
If it is not possible, that is fine.  This is my last point of call for support, any help would be much appreciated.
Thanks in advance.
Steve
DISCLAIMER: This email and any files transmitted with it may be confidential, legally privileged and protected in law and are intended solely for the use of the individual to whom it is addressed. The copyright in all documentation is the property of the Borough of Poole and this email and any documentation must not be copied or used other than as strictly necessary for the purpose of this email, without prior written consent which may be subject to conditions. Any view or opinions presented are solely those of the author and do not necessarily represent those of the Borough of Poole. The Borough of Poole reserves the right to inspect incoming and outgoing emails. If you have received this email in error please contact the sender by return and confirm that its contents have been destroyed. Telephone enquiries should be directed to the Borough switchboard on 01202 633633.'
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/e0a90a73/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/e0a90a73/attachment-0001.png>
Type: image/jpeg
Desc: image004.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/e0a90a73/attachment-0001.jpg>
