[Qgis-developer] FW: Support | Custom install for XenApp | Removing menu options
Jonathan Moules J.Moules at hrwallingford.com
Tue Nov 11 09:54:39 PST 2014
Hi Steven,
Just a notion, and this is more of a “last ditch attempt” than anything else, but I’m reasonably sure that the pyramids are created using GDAL’s gdaladdo.
So one possible option is to remove/rename gdaladdo.exe. In theory this would disable the functionality.
I can’t test it myself because local admin privs stop me. But it might be worth a try if you’re feeling bold. Not sure if it’ll affect anything else; gdaladdo only seems to do pyramids, so might be ok.
Cheers,
Jonathan
From: qgis-developer-bounces at lists.osgeo.org [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Steven Campbell
Sent: Tuesday, November 11, 2014 2:45 PM
To: 'qgis-developer at lists.osgeo.org'
Subject: [Qgis-developer] FW: Support | Custom install for XenApp | Removing menu options
I’ve been trying to remove some functions from QGIS so we can deploy a stripped down version of it into a Citrix - XenApp 6.5 environment.
I’ve posted on the QGIS forum<http://gis.stackexchange.com/questions/120199/qgis-deployment-in-citrix-xenapp-how-to-remove-pyramids-from-the-image-proper> to see if anyone could help me with this set-up.
I need to remove the ability to build pyramids on QGIS when it is installed in XenApp (GIS team will use PC’s to do rendering\pyramids overviews etc).  I can use the customization tool built in QGIS to remove the Menu options, however I need to remove the ‘Properties’ (or just the Pyramids) option from the context menu when you right click on an Image.
Here is an image of what I am trying to remove:
[cid:image001.png at 01CFFDD8.79EC3440]                         [cid:image002.jpg at 01CFFDD8.79EC3440]
I need to prevent this option from being used on our XenApp environment due to the amount of memory it grabs.  If a user runs this on a highly loaded server it could cause outage for the other users on that server, if possible I’d like to configure GIS to avoid the option being used by mistake.
If it is not possible, that is fine.  This is my last point of call for support, any help would be much appreciated.
Thanks in advance.
Steve
DISCLAIMER: This email and any files transmitted with it may be confidential, legally privileged and protected in law and are intended solely for the use of the individual to whom it is addressed. The copyright in all documentation is the property of the Borough of Poole and this email and any documentation must not be copied or used other than as strictly necessary for the purpose of this email, without prior written consent which may be subject to conditions. Any view or opinions presented are solely those of the author and do not necessarily represent those of the Borough of Poole. The Borough of Poole reserves the right to inspect incoming and outgoing emails. If you have received this email in error please contact the sender by return and confirm that its contents have been destroyed. Telephone enquiries should be directed to the Borough switchboard on 01202 633633.'
This message has been scanned for viruses by MailControl<http://www.mailcontrol.com/>, a service from BlackSpider Technology
Click here<https://www.mailcontrol.com/sr/59afDHgHmtHGX2PQPOmvUvmldA89nuwl+uVwa3cC2WMYqA+tYINQQcgt!bBGUvwP+pKcdHXFkgmOdoKZwoXR0w==> to report this email as spam.
HR Wallingford and its subsidiaries uses faxes and emails for confidential and legally privileged business communications. They do not of themselves create legal commitments. Disclosure to parties other than addressees requires our specific consent. We are not liable for unauthorised disclosures nor reliance upon them.
If you have received this message in error please advise us immediately and destroy all copies of it.
HR Wallingford Limited
Howbery Park, Wallingford, Oxfordshire, OX10 8BA, United Kingdom
Registered in England No. 02562099
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/9d0048ac/attachment-0001.html>
Type: image/png
Desc: image001.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/9d0048ac/attachment-0001.png>
Type: image/jpeg
Desc: image002.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20141111/9d0048ac/attachment-0001.jpg>
