[Qgis-developer] Drag n drop on OS X
Larry Shaffer larrys at dakotacarto.com
Mon Jun 8 20:07:46 PDT 2015
This can be fixed for Qt 4.8.x, but requires direct access to the Cocoa API
when needed to introduce the non-Qt-source workarounds noted in the
QTBUG-40449 [0].
Btw, this is an example of my old PR [1] to introduce abstracted calls to
the OS (Mac for example, with Objective-C++) to handle changes in OS API
libraries and keep such workarounds in one place instead of peppered
throughout the source tree. Especially for those instances where Qt fails
us, but a direct call to the OS could be abstracted for a workaround where
needed.
Unfortunately, it is a significant change that needs really tested well,
and certainly not reasonable to introduce into 2.10 as a fix, as it is more
of a feature.
I never upgraded to 10.10 for several reasons, but am about to, or I would
have noticed this nasty bug sooner.
[0] https://bugreports.qt.io/browse/QTBUG-40449
[1] https://github.com/qgis/QGIS/pull/1084
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
On Sat, Jun 6, 2015 at 5:10 PM, Stefan Ziegler <stefan.ziegler.de at gmail.com>
wrote:
> Thanks for looking into it!
> Stefan
> Sent from my iPhone
> On 07 Jun 2015, at 00:07, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On 7 Jun 2015 7:13 am, "Stefan Ziegler" <stefan.ziegler.de at gmail.com>
> wrote:
> > Hi
> > I'm running into this issue: https://hub.qgis.org/issues/11399
> > Could this be a solution? https://bugreports.qt.io/browse/QTBUG-40449
> > Since 2.10 is coming soon, it would be great to have a solution. I'm
> using QGIS master on Yosemite built with homebrew.
> Stefan,
> I looked into this, but it's non trivial. We need to wait until the osx
> builds switch to qt5 before this issue will be fixed.
> Nyall
> Qgis-developer mailing list
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20150608/a24e5786/attachment-0001.html>
